Drive Shafts 73-79 and 67-72
Old 08-29-2001, 09:26 PM
Matt67's Avatar
Matt67
Matt67 is offline
Are drive shafts for 73-79 short-bed F-100's the same size as 67-72 short-bed F-100's? I want to put a 351M with a C-6 in a '67, and want to just get a stock shaft from somewere instead of getting a custom one made. I also want to put a 302 with a C-6 in the same type truck, what stock drive shafts will work with this one? Both trucks have 9" rearends.
Thanks a bunch,
Old 08-29-2001, 11:06 PM
ecarter50's Avatar
ecarter50
ecarter50 is offline
73-79 has 2" longer wheelbase than 67-72. engine size won't change driveshaft lengh any 67-72 with same wheelbase and c6/9" rearend should work. a salvage yard will have a Hollander interchange manual which will tell what lengh you need.
Old 08-30-2001, 12:26 PM
Matt67's Avatar
Matt67
Matt67 is offline
Thanks Carter,
I guess a 67-72 FE-block truck with a C-6 is what I should be looking for.
Old 08-30-2001, 12:42 PM
tetraruby's Avatar
tetraruby
tetraruby is offline
roger dowty
1978 - 1996 Big Bronco
03-23-2009 11:57 AM
1968 F250camper
04-13-2007 03:47 PM
tiredone
08-12-2006 04:17 PM
StockMan
11-19-2001 10:41 AM
rfgre
32
07-11-2001 08:14 PM
Quick Reply: Drive Shafts 73-79 and 67-72
