Squeak(chirping) in 2006 diesel from engine
#61
#62
#63
The chirp sound I'm referring to is not a squeal like you hear from belts, etc but a distinct timed metallic "chirp" that increases or decreases with engine revs at deaccel and light throttle. Almost a tink- tink- tink sound like an internal metal flap of some type is opening and closing. Only occurs after a warm up and then increases in volume as temp increases. Ford tells dealer it relates to the hpop pipe.....?
I only hope this is not the beginning of the end of my past positive feelings for the super duty line.
#66
#67
#68
I've heard the noise you're describing in many '06 trucks and some '05 trucks. Almost sounds and behaves like some type of injector noise. Usually I hear it on decell/coast and can manipulate the noise with slight accell pedal application. There is no fix yet that I'm aware of.
Exactly what mine does. 2006 F350 Dually.
Mark
#69
I'm curious as to why this issue seemed to disappear after 2006. There are a couple long threads on other forums around late 2006. People were quite upset then everyone just quit talking about it. I'm just bringing this back up because I remember when my truck did not have this issue, it actually started about 700 miles ago.
#70
If anybody is still subscribed to this I have a question. Did your noise just go away, and is that why all the chatter just stopped. I had a noise for about 12k mi. Then it just went away. I guess if the op's issue went away then that would explain why the posts just stopped. Maybe they got paid off ( hush hush $$$). Dunno.
#71
if the chirping is not the belt, then pop the hood open, and check to see while running the engine, and see any weird movement. it may be the harmonic balancer coming loose and it may be wiggling down below. it's right in front of the engine and all the way down below. i'd check all the externals, then proceed to the internals.
#72
#73
I had the chirp for a long time. Thought I would put my lifter video here. This could cause it for sure. Credit Mike(mchan68) for the diag.
http://youtu.be/LdeMW-gwe-o
#74
10 bad lifters 6.0 powerstroke - YouTube
#75
Motorcraft 15/40. 582k. Odo still counting. The engine hour stopped n stayed at 9999.9.
Btw, I shut the truck off with the key before tear down. Main drive ability issue was a failed inj copper washer. Truck was squeaking tho. I prob could've changed inj, then drove, for how long?????? 1 mile. Lol
