Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-12-2006, 08:29 PM
empiretc's Avatar
empiretc empiretc is online now
Garage is empty, add now
empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.
Straight WVO vs. Diesel -- Cheaper???
I have heard of some people running straigt wvo in diesel vehicles, but couldnt find much info on what would be needed to do that.
I was grocery shopping the other day and saw 1gallon of wvo for $2.49. I talked to a friend that worked there and he said they pay $2gallon on the wholesale= $500 a pallet 250gallons. That is cheaper than diesel at the pump.
What do you guys think?
__________________
If the lunch meat called spam became the catchword for a depersonalized email message, then social networking should be known as soylent green!
Please, do not text & drive: http://www.youtube.com/watch?v=gRwfq7Igvxc
-David
  #2 (permalink)
Old 06-12-2006, 09:10 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
WVO is waste vegetable oil. Typically it is free for the asking from resturants and such. Much cheaper than diesel.
Virgin oil by the pallet, while still cheaper than diesel, probably wuldn't be worth it considering the time it would take to offset the cost of the conversion kit.
The sponsor of this forum, Lesk WVO, would be the one's to talk to about it.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #3 (permalink)
Old 06-12-2006, 09:47 PM
empiretc's Avatar
well, i was looking at wesson vegetable oil (wvo), LOL.
__________________
-David
  #4 (permalink)
Old 06-12-2006, 09:54 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
haha...gotcha
Seems like there's something else about new oil that makes it harder to run than the used stuff, but I can't remember what.
One of the guys in the know will be along to straighten us out.
__________________
Scott
  #5 (permalink)
Old 06-12-2006, 11:53 PM
DOHCmarauder's Avatar
DOHCmarauder DOHCmarauder is offline
DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.
Totally into this concept and am looking for a suitable vehicle to do this setup.
Here's what I've garnered;
WVO is basically any garbage oil you can find.......you have to install a separate fuel tank with a dedicated heater. the system will also have it's own filtration.
The vehicle will be started the normal way on regular dino diesel, after the WVO is heated up to it's required viscosity you can switch to the alternate fuel. You MUST also shut your vehicle down on regular diesel so as to clear the lines.
Running virgin oil (like the Wesson) can be run the same way........but why???
Bio-diesel refineries take that virgin oil and add chemical (lye and some other stuff) so as it can be run STRAIGHT in the vehicle's stock tank........but that's not WASTE VO.
I'm real excited about picking up a used Mercedes or VW and trying the WVO....already have a couple resturants that'll give me their fryer oil for free!!!
Sorry if you already knew all this.........like i said, looking forward to no more $80 fill ups once a week!!
__________________
If Ford, GM, Chrysler and even the U.S. government can buy foreign, why can't we???
  #6 (permalink)
Old 06-13-2006, 09:55 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
Because virgin oil is still VO and has the same viscosity problems as WVO
Not exactly.
The lye and some other stuff that are added actually convert the VO into an oil that is very similar to regular (petro) diesel by stripping out the glycerine. BD has the same viscosity and molecular weight as petro so the two can be mixed and used interchangably.
The lye etc added to the VO during the conversion must be removed before the BD can be used as fuel, they are not there just to allow you to run straight VO in a stock tank
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 06-13-2006, 12:14 PM
Quote:
The "But Why" question simply was meant to ask why run virgin VO @ $2.50 a gallon when WVO is free.
Not exactly.
Not sure what I wrote different........but thanks for the detail.
Again, thanks for the detail.
Of course they are..........it's part of the refinery process. Without it, you couldn't run it straight.
__________________
  #8 (permalink)
Old 06-13-2006, 02:59 PM
Phydeaux88's Avatar
What you wrote earlier seemed to imply that you thought the lye and methanol were an additive to VO that allowed it to be run as normal diesel. That is not true and is in fact a recipe for disaster. I was trying to prevent you from engaging in that activity. If I misunderstood your understanding of the process I apologize.
I still see some evidence that you do not totally understand what the conversion of VO to BD involves. If I am wrong I apologize again but I think it is important.
First the conversion process is not in any way a refining process.
It is a chemical reaction (base catylized trans-esterification) in which the 3 fatty acids are severed from the glycerol (glycerine) back bone of Veg Oil. The glycerol is extracted and the fatty acids are converted into Methyl Esters. The resulting molecules are the same size and have physical properties similar to the straight chain hydrocarbon that form diesel. Chemically the Esters have two oxygen atoms, in their makeup, that are not present in reg diesel. The added oxygen accounts for the reduced pollutants found in BD exhaust products.
__________________
  #9 (permalink)
Old 06-13-2006, 11:35 PM
Fair enough........refining is the incorrect term. I certainly would not attempt to create bio without staying at a Holiday Inn Express for at least one night!!!
The bottom line to me was the diff between WVO and Bio-diesel is the ability to run one (BIO)using the existing fuel system (after the chemical reaction) and the other(WVO) having to have a separate tank/heater/filter sytem.
You're correct in that I don't know all the details...........but I think I know the main differences.
Also was trying to understand why one would run virgin oil that costs nearly the same as diesel ( within $.60 a gallon)in a system designed to run free fuel????
Also understand that 100BIO from co-ops is under $2.00 a gallon.........again negating running VO in a WVO system.
__________________
  #10 (permalink)
Old 06-14-2006, 12:09 PM
Phydeaux88's Avatar
I think most of the objection to Bio comes from the time and cost to run the conversion cycle.
Folks compare the production cost, around $1.00/gal, and the time needed for production of Bio then compare it to the cost of WVO, $0.00/gal, and the significantly less time to prepare.
They think that WVO will save $$$. I think the fail to consider the hidden cost of using WVO first the conversion kit and installation cost about twice what an Appleseed Processor costs, second when the time comes to replace the truck their pool of potential buyers will be greatly limited.
__________________
  #11 (permalink)
Old 06-14-2006, 01:07 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
I just completed my WVO conversion on my 95. Total cost for conversion and WVO collection equipment $1000. My only recurring cost is filters.
I burn 95% of all oil I collect. With fuel oil over $3 a gallon my return on investment is 330 gallons of WVO.
I would say the greatest risk is WVO done wrong it will destroy you engine.
That is a very large hidden cost.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #12 (permalink)
Old 06-14-2006, 02:36 PM
Phydeaux88's Avatar
Willbd
I agree with everything you say, my big concern is the marketability of your truck at time to sell. You may not easily find a buyer that wants to do WVO.
I dont know if it is possible to "go back", if it is that may be a moot issue.
$1000 for everything seems a little low to me did you add the fuel heaters etc?
__________________
  #13 (permalink)
Old 06-14-2006, 02:56 PM
I have 3 heat exchangers and a heated Radcor fuel filter. 1 heat exchanger in the front tank.
18 feet of heated fuel hose and 1 artic fox heat exchanger.
It took me 12 hours to complete the conversion.
__________________
Bryan Will
Tags
1999, 60, alabama, buyers, cheapest, diesel, f250, ford, fuel, green, lesk, oil, straight, virgin, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
