FE parts catalogs
Old 05-18-2006, 06:02 PM
fords_forlife's Avatar
fords_forlife
fords_forlife is offline
FE parts catalogs
hey guys, my brother is going to be rebuilding a 390 FE for a '79 thunderbird and wanted to find some parts catalogs that deal with these engines. not just performance parts but everything. anybody have some sources from which i could order a catalog. thanks
FORDS_FORLIFE
Old 05-18-2006, 10:58 PM
AXE168's Avatar
AXE168
AXE168 is offline
I got alot of stuff from P.A.W on the last 390 i built
Old 05-24-2006, 04:44 PM
pbear6969's Avatar
pbear6969
pbear6969 is offline
LMC.....www.lmctruck.com
Dennis Carpenter....www.dennis-carpenter.com
Blue oval truck parts.....http://blueovaltruckparts.com/catalog
Just some I like, there are more.....
I just have a question not pertaining to this thread, but why the heck did Ford make the parts for these engines so complicated??? I had a rod bad and got another one with the same casting number but the dern bolts were bigger. aka for a 427...HOW DUMB.... This isn't the only bs I have run into with parts for these motors. I see why people put chevy motors in ford vehicles now. LOL Sorry had to vent a little.
Old 05-24-2006, 11:10 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
Not dumb, but smart and cheaper for everyone. They changed the bolts because they were the weak place on the rods. It's smart (read cheaper) to just change the problem part. So the rod would have worked fine, in fact a lot of rebuild places just upgrade the rod bolts as it is cheap and makes the part not fail regardless of what the customer puts it in. Go build your chubby as any moron can!
Old 05-25-2006, 11:24 AM
pbear6969's Avatar
pbear6969
What I was saying was dumb was the fact of the casting number. All they had to do was make it a B instead of C or something like that. I am putting the ARP bolts back instead of the ford bolts anyway. ex...C6AE-C....make it a C6AE-B for bigger bolts.
Old 05-25-2006, 03:18 PM
Bear 45/70's Avatar
Bear 45/70
Like I said, the rebuilders are doing the bolt upgrades and they don't ever change the numbers. Ford usually did change the suffix or prefix. Actually a suffix of A means first in the series and B is the second and c..........
Old 05-25-2006, 06:02 PM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
Both C3AE-C and the later C7AE-B rods both came with big and small rod bolts. These for the most part are listed as 427 and 428CJ rods in big bolt version. Not many books mention there was a small bolt version also with the same casting numbers. Both C3-C and C7-B rods are identical castings other than the large and small rod bolts. I've often found them mixed in engines I've had through the years. But all were the large bolt version.
G.
