Adding cruise control to a 2005 F150 4.2L
Hello! I'm trying to figure out how / if cruise control can be added to a 2005 F150 with the 4.2L V6. I bought an aftermarket kit, popped the hood, and then learned all about electronic throttles . What (aside from adding the cruise control switches) do you have to do?
Thanks!
Jamie
Thanks!
Jamie
Cruise Control
Unfortunately my local dealer seemed somewhere between clueless and uninterested. Maybe I'll see if I can get a wheel off of eBay like it was suggested and talk to another dealer about reflashing the PCM. Has anyone here had this done (or done it if you're a tech)?
Thanks again!
Jamie
Thanks again!
Jamie
Jamie,
I had purchased my steering wheel for about 100bux, (98.xx) from a dealership in the next state over (NC) and went back home to Greenville and had my dealership put it on. This was also a clueless thing for them too. But after careful coaxing and the potential that I'd bring'em return buisness for similar things, I talked them into it. They figured if their techs knew how to replace one for (any) reason they should know how to put on in for the first time. I did remind them however that it would have to be turned on in the pcm/ecm (they prolly knew already). So right less than 70bux and a hr later, out comes my truck with cruise control. Final cost ...approx. 169$ including a brand new steering wheel. I would have attempted it myself, but I was home on vacation- and wanted to keep my wrench turning to a minimum.
Originally Posted by aerio
PLS post P/N #
http://www.fordaccessoriesstore.com/fas/b2c/catalog.asp
Black Speed Control
Part Number: 4L3Z-9A818-AAA
MSRP: $165.93
Note!: I didn't pay nearly that much by purchasing it locally from a dealer. (Dale Jarrett Ford) The dealer had 4-5 on the shelf- everyone else would have had to order it. The 165. is pretty close to what I paid for the kit and install together. I purchased it at Dale Jarrett and had my Local dealer (Fairway Ford) do the swap.
Web addy and contact info....
... do you have a # for Dale jerrit thanks
http://www.dalejarrettford.com/Department-Parts.aspx <-web address
Phone: 704-283-0616
Fax: 704-225-1671
Email: ()
I see y'all are clueless as the ford dealer about installing cruise control on the 2004 to 2008 F150.
www.bought4less.com sells the cruise control kit for $120. It must have the ECM flashed.
Great thing is it looks and operates like factory.
I dunno, maybe this module wasn't available way back in '06 when this thread was first posted. And '07's and '08's weren't even being made yet.
Stewart
