missfire, need help with diognosis
Old 05-17-2006, 05:22 PM
taxas grand's Avatar
taxas grand
taxas grand is offline
2000 F150 4.6 Misfire started 2 months ago.
...Changed plugs no help
...Had autozone check code, misfire #6
...Installed new COP...No help
...Rechecked code, missfire #6 and #3 Added injector cleaner.
...Misfire stopped and Light went out after 2 tanks of gas
...Misfire back after 3 weeks, but much worse
...Autozone code check missfire #2,3,4
...added injector cleaner, no help
...Changed fuel filter, no help
How do I check for vac leaks? Cant see or feel lines in back of engine. I have a feeling I have a vac leak. Test gauge?
What is a logical procedure to diognose this problem?
Old 05-17-2006, 07:28 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Vacuum leaks usually don't cause misfire codes. Take the plugs out and make sure none of them are cracked.
Old 05-18-2006, 03:43 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
ALso, make sure when you pull the COP's that there is no moisture on them. It will cause them to short out is water gets into the spark plug pocket area.
Old 05-19-2006, 12:13 PM
taxas grand
Water was the problem. I tapped the COP on the table and drops of water came out. Water must have evaporated, entered the COP from the bottom and condenced inside.
Old 05-19-2006, 05:28 PM
70f100longbed
Have you washed the engine lately?
