brake shift interlock, solenoid...nope..no brake lights
#31
#32
If I had just followed up on HomerWinzlow's suggestion in post 10...I would have been better off (hindsight IS 20/20). The problem was right in the harness at the brake switch. the wire had broken right where the insulation was stripped. I had never taken the actual harness apart. I was thinking that is I probed the contact inside that I was doing sufficient. It also didn't hep that I was using the meter improperly. That caused this to drag on for a while. But thanks all for bearing with me.
Problem:broken wire in harness.
Time to diagnose: altogether including trim removal/replacement 5 hours
Time to repair: 1 hour
Time on computer: 2-3 hours (total)
Actual dollar cost of repair: <$20 (including new bulbs)
Dealership cost to perform diagnosis/repair: ????????
I've got no problem with dealership. The parts mgr and service mgr both gave me some good advice and they didn't sell me an electrical part which I wouldn't have been able to return. I wanted to avoid dealership for 2 reasons: 1) didn't want to pay $65/hr...that always hurts when it is a repair that I feel that I can do and 2) couldn't tie up me truck.
Thanks again to all
Dan!
Thanks again to all
Dan!
#33
Same thing happened to me today. Finished work, went to my 2001 F-150 to drive home and started but could not get it out of Park. Power windows would not work either. I think mine problem is in a relay somewhere. I turned my ignition switch to on, pulled the shifter selector to park, started the truck and drove home. I did not check my brake lights, need to do that tomorrow. I need to take the truck in for the recall for cruise...wonder if the problems are related?
#34
#35
gearloose1
01-01-2020 05:03 PM
wjstarck
1961 - 1963 F100 Unibody
03-17-2017 03:00 AM
Frank250Tank
07-01-2016 07:12 AM
