Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-14-2006, 02:28 PM
1976 ranchero 1976 ranchero is offline
Garage is empty, add now
1976 ranchero is starting off with a positive reputation.
can anyone help a new guy with explaining the timing adjust procedure
I have a 1976 ford ranchero
  #2 (permalink)
Old 05-14-2006, 08:17 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Welcome to the site
Please post a new topic (your own thread) rather then placing it in someone elses off topic thread.
I'll get a mod to move it out on its own.
  #3 (permalink)
Old 05-15-2006, 02:03 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Hello- Welcome to FTE! I have Split and moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #4 (permalink)
Old 06-10-2006, 09:38 AM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
Probably the easiet way aside from using a timing light, is to use a vacume guage. Loosen the set bolt located at the base of the distributor & slowly rotate the distributo until you get the highest vacume reading. drive the vehicle with the ac on & check for pinging (detonation), deduce the timing about 1/16 of an inch until the pinging is not heard.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #5 (permalink)
Old 06-10-2006, 09:47 PM
Texas Cop Car's Avatar
Texas Cop Car Texas Cop Car is offline
Texas Cop Car is starting off with a positive reputation.
Adjust Timing
My method is way more complicated than that.....Start The motor, Hold the Brake, Put it in gear, Floor the gas, Adjust the distributer till it (knocks)(pings) Retard the dist till it stops, tighten the bolt!!!!! Then get a timing light and adjust till right!!! I have been doing it this way for 30 years and it still works.........
__________________
Texas Cop Car
  #6 (permalink)
Old 06-11-2006, 02:17 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
the highest vacuum reading will be WAY too far advanced. just get a timing light, the cheapest one you can find will work.
as far as procedure, remove the air cleaner and plug any vacuum hoses that may be disconnected(golf tees work real good for this). disconnect and plug the vacuum hose(s) from the advance can, if there are 2 don't get them mixed up! loosen the distributor hold-down bolt and leave it snug enough to hold, but able to turn the dizzy. connect the timing light to the + and - of the battery and the #1 spark plug wire. clean off the balancer so you can see the marks and the pointer well, you can use a dab of white paint or such to highlight the desired setting on the balancer. start the engine and shine the light at the pointer. turn the dizzy to align your mark at the desired setting to the pointer. shut of the engine and tighten the hold down bolt. start the engine and verify that the setting did not move while tightening. shut off the engine and reconnect the vacuum hoses and disconnect the timing light. replace air cleaner and reconect vacuum hoses.
Tags
2006, adjust, f150, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
