bent push rod on cam break in
Improper valvetrain geometry which can include; coil bind, wrong pushrod length, to much lift for rocker arm, bent valve, improper machine work, improper keepers, wrong shims, etc. The valve train on the 335 and 385 series engines is not simply a bolt together affair. Clearances must be carefully checked. Unfortunately you may also have ruined the cam which means cam and lifter replacement.
I had this, was from the machine shop installing the intake spring on an exhaust valve,or rotator was put on an intake valve, can't recall, was OK with stock cam, but limited required lift with the RV cam. I had the heads pulled and all the old springs were replaced, I've not had the problem since it was put back on assembled correctly.
