Edge Evolution on a 2006 F-150 5.4ltr 4x4 Crew cab
Does anyone out there have an Edge Evolution on their 2006 F-150 5.4 ltr? I am searching for a tuner and I heard Edge is the best.
My 2006 5.4 falls on its face when I punch it. My wifes 2004 Expedition runs considerably stronger than my truck which is supposed to be a new, improved and more powerful engine but it sure doesn't feel like it.
I don't want to spend alot of money and I don't care about gas mileage. I'd just like the truck to shift stronger and have a little better acceleration. Does anyone have first hand experience with the 2006 engine and tuners? Thanks.
Welcome to FTE afc1261. Yeah, I have an Edge in my 06 5.4 Supercrew. I love it. You will definately get stronger shifts, as well as better acceleration. I also get better mileage (when im paying attention). It really is a great unit. The heads up display with 4 selectable screens is damn cool (I show mph, rpm, ampg, and impg). I got mine through the FTE sponsor Discount Power Parts. They had the best price I could find on the net! Hope some other owners can chime in as well.
I don't know crap about tuners, so i don't want to blow my engine messing with one. Are they ok for n00bs to play around with?
Thanks.
Rob.
The install is a simple plug and play setup. Just plug the cable into the OBDII port under the dash, run the wire up to the pod (pics of the pod mounted in my gallery), turn the key on plug the cable into the Edge. After the warnings label comes up just hit menu and pick the program that you want to run. So it is very very easy. If you just level the programs in the "stock" forms they are good, but if you customize them they can be awesome!! You can screw up the truck if you make drastic changes to the programs, but I wouldn't worry about it.
Paul
Paul
Very Easy To Take Out. I Have A 06 5.4 And Love The Edge. It Took Me About 4 Min And 23 Sec To Install. I Run Level 3 With The Timing At +1. It Really Does Wake The Truck Up. My Best 0-60 Time Was 7.2 Sec. This Was On A Cold Morning, 52 Degrees, 1/2 Tank Of Gas. My Ave. 0-60 Time Is Between 7.9 And 8.2. I Do Have A K&n Fipk And Magnaflow Si/so Cat Back System. Still A Considerable Difference Than Stock. Just Use The Stock Programs And You Will Not Screw Anything Up. I Tried To Modify The Level 3 Pretty Aggressive And My Truck Would Not Allow The Settings, It Would Go Into Failsafe Mode And Not Allow The Truck To Go Faster Than Idle. Go For It, You Will Not Be Disappointed.
Looks like you all answered it for me. There is a rather informative .pdf file on these Edge units, over at www.edgeproducts.com
Originally Posted by awu_gigabyte
What was the install process like? Can you screw over your truck with this thing if you don't know what you're doing?
Thanks.
Rob.
Thanks.
Rob.
I got lucky and found a used one on Ebay for a lot less than a new one. Made my decision that much easier.
I suspect you'll like the Edge.
