Smell in Escape
Smell in Escape
Hello!
I have a 02 V6 4x4. Lately, when starting the vehicle, a strange smell comes out of the air vents. I have the AC on, and the smell started after using the AC. I have tried leaving the vents in different positions (not in AC mode) but no help. It's a musky smell, kinda like wet carpet. However,it's gone after about a minute or so. If I turn the car off and back on, I smell it again. Any clues on what it is and how I can fix it?
Greetings
Greetings
on
1 Post
It's from using the A/C. It is moisture that sits in the vents after the vehicle is shut off. One way (I have heard) to get rid of it is to turn the A/C off and have just outside air coming through the vents a couple minutes before you turn the vehicle off. I have the same smell in my Focus as well sometimes.
-Matt
-Matt
T.S.B. # 03-05-06
* It involves a procedure to apply Motorcraft A/C Cooling Coil Coating To The A/C System Then Install Air Inlet Vacuum Motor Bleed Valve.
* Please note that the Dealership has to determine that the odor is actually generated by the A/C system before the T.S.B. can be performed.
curlb
03-30-2004 04:20 PM
