Dash and Tail Lights OUT!!!! Help
Found It!
I replace the Maxi fuse, a 25 amp fuse (both under the hood) and the 25 amp fuse in the dash. This was after I found a rubbed wire from my trailer connector in the bed. Must have done something quick to burn all those at once.
I'll tell you guys this. Don't buy those cheap switches for your headlights. I had to go back and get a Borg/Warner. The chinese switch played my radio when I turned off the truck. I could switch on my parking lights and the radio would go off. After putting the voltmeter to it I found the switch would short to the ignition connector on the switch. Pretty schweet!
Thanks so much for everyones help. I felt like I had covered the bases but knew I could count on more help from this site!
