transmission question
So far I am very impressed with the Chip, it is one of the only ones I could use with the PCM code that I have. I was looking for towing performance, play performance and a High Ilde function to charge the trailer batteries. All is good with the new chip. I installed the transgo HD2 kit, I would highly recommend the kit. It is pretty involved to install, only down side. If you tow a lot and use 2 and 1 for down shifting, you'll want this kit. If you pretty much use as a daily driver, still recommend the kit, but the Sonnax kit from blackclouddieselperformance would do the trick. Check out ebay for 4r100 transgo, there are many options. If you don't have a kit yet, I highly recommend one for sure, you'll be very surprised at the amount of "feelable" torque you'll gain.
897.3idi
29
02-09-2012 04:17 PM
tony4mitchell
04-27-2011 01:49 PM
