Tranny cooler install question?
Bottom line should be the return to transmission.
Warm water is returned to the top of the rad from the engine and cool water sucked into the engine from the bottom of rad.
If that is so then it makes sense that the coolest part of the water column in the rad is on the bottom, and as such, any oil cooler would return to the transmission from this point also.
Dialtone
Dialtone
