tdc and did i mess up
it all started when my coil packs got wet and i just figured i would go ahead and change plugs well i was taking off the 7 mm bolt that holds the cp on and i am stupid for this but i had the plug out of the cycl. behide it and the socket droped on top of the piston tried everything to get it out well i had to take the head off and get it out and couldnt get the engine on tdc because it wouldnt turn over with the socket in it well i marked the timing chain before removel and didnt turn nothing over at all and put it back together and i checked tdc by using a long extention and pulled the 1 plug out and let the extention touch the top of piston and when i cranked it by hand either way off tdc the extention went down so is my timing right
now it will start but i know that dont mean timing is right and as soon as i touch the gas it dies out seems to idle okk and sometimes it idles rough but either way it quit at the touch of the throttle
