Modular V10 (6.8l)
V10 Pictures For Everyone
Old 03-24-2006, 09:16 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
No wonder they came out with the 3-valve... small bore = small valves.
Only way to get enough breathing room for the long stroke is to go multi-valve.
HOWEVER, using simple multiplication and division, here's an example of exhaust valve sizes.
Ford 428 Cobrajet, FE-series motor, has a 1.650" exhaust valve, 2.09" intake. I used a 2.060" intake and 1.650" exhaust on the 390 I built for my '74 highboy. And, 8 cylinders. I can't believe I remember this from 17 years ago...
So, do something like this:
390, 1.650" exhaust valves. For all 8 valves, that's .03384 inches of valve diameter per cubic inch.
415 cube, V10, 1.41" exhaust. For all 10 valves, that's .033975 inches of valve diameter per cubic inch.
That's really NOT a bad ratio... that's a pretty good-sized exhaust valve for the cylinder's size.
Intakes:
390: 2.060" valve, .04225" per cubic inch.
V10: 1.75" valve, .042168" per cubic inch.
Does ANYONE ELSE notice that the figures are almost exactly the same between the two motors?
That's VERY weird...
Old 03-24-2006, 11:12 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is online now
Its Comin Right for us!
Received 1,441 Likes on 937 Posts
those are some sweet pictures....never seen the inside of a 10
Old 03-24-2006, 11:58 PM
88svt's Avatar
88svt
88svt is offline
Talking
Originally Posted by krewat
That's why I want a blower - so my motor doesn't have to SUCK anymore...
Old 03-25-2006, 12:20 AM
Bdox's Avatar
Bdox
Bdox is offline
I have a v-10 in an E series, so I had never really SEEN one before.
And I am in love with that motor!!!!
Old 03-25-2006, 02:30 AM
captchas's Avatar
captchas
captchas is offline
Guest
matt
nice shots of the v10 but i want the flat head sitting there 1st. or did not any one notice the 49 to 53 8ba or 8rt sitting along side of the v10 block.
art don't you have a blog in you site also. i lost the address again when i redid my puter with this 400 gb drive and new mb.
Old 03-25-2006, 04:44 AM
10strokin's Avatar
10strokin
10strokin is offline
Talking
aahhh the flathead. there are so many parts available for these today that i really want to build it. and considering i am leaving in about a half hr here to go to the spring spectacular car show and swap meet at daytona speedway in my bid 10, i will probably see a bunch of flathead street rods today. give me the bug even more. hey you guys in the northeast, SHUT THE DOOR! its 39 degrees here this morning. the big 10 is groaning! matt
Old 03-25-2006, 09:31 AM
captchas's Avatar
captchas
captchas is offline
Guest
not much warmer here in the norwest side of n.j. 38 degs this am at 1030 hours
Old 03-25-2006, 10:17 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Originally Posted by captchas
matt
Oh, I saw it in the background there
What blog? What site? Whatcha talkin' 'bout dude?
Old 03-25-2006, 10:22 AM
captchas's Avatar
captchas
captchas is offline
Guest
the specail one you told me about that i signed up for. yep i'm funkie old dude also. got any other good names for me? old fart fits the best!
Old 03-25-2006, 11:19 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
http://forums.kilonet.org
Shh... don't tell anyone!
Old 03-26-2006, 01:37 AM
biz4two's Avatar
biz4two
biz4two is offline
Intakes:
Well...if it is good enough for a 428FE CJ...it has to be good enough for a V10.
What surprised me what the smallish size in the chamber area. I suppose it is directly related to the size of the cylinder, but wow...only 42.45cc. As a comparison...with the FE alum Edelbrock head (basically a cast of 428 CJ) that measures out at 72cc. Quite a difference...
Still nice to know...
biz
________________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old 03-26-2006, 09:00 AM
10strokin's Avatar
10strokin
Talking
speaking of long stroke engines like the 428 ford, i thought long stroke engines make all their power on the lower end of the scale, hence the long stroke. well the bore and stroke on the V10 is 3.55 and 4.16 respectively. with a long stroke like that, why does my V10 make lots more power in the mid to upper range. THIS BABY LOVES TO REV! any answers? matt
  #28
Old 03-26-2006, 11:14 AM
jaybird's Avatar
jaybird
jaybird is offline
Intake/head combo,cams,
Its mostly all about the heads and intake plus the cam design ;they all are designed for a specific rpm band and then you have 10cylinders and the revolution,firing efficiency helps too.This engines stroke does not hinder the mid and high end rpm like the heavier longer stroked dinosaurs..
With that said everything has its limitations and you can only force it to do so much and then it reaches its limit.
Sure you can add a power adder like a supercharger to help out on compressing more air in and out but naturally aspirated has its limits to a degree.The 3valver is plain and simple a more efficent and better breathing design than the 2valve in this V10.
I'd like to see a dyno for a 3valve supercharged V10 triton;that would be a sweet pkg for sure(hello FORD wheres our chief?)
The key to it all is to get the engine to not have to work so hard(slow down)trying to get air in and out .
The 3valver does this chore more easily than the 2valver because it has smarter brains .
  #29
Old 03-26-2006, 11:30 AM
Bdox's Avatar
Bdox
Bdox is offline
My experience with the V-10 is limited to my own two valve. My opinion is that it does have good low end torque, but the power in the higher rpm range is really excellent!
  #30
Old 03-26-2006, 12:12 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Long stroke just means more leverage to turn the crank.
There's really no "long-stroke equals low-end-torque and no high-end".
There's plenty of torque all over the place
Quick Reply: V10 Pictures For Everyone
