F-100 Ranger Steering
I realize that the search feature is down but please surf through the old threads and you will find numerous ones on Power Steering conversion's for the 67-72 Trucks.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
THE 2003 LINEUP
#88 Dale Jarrett-UPS-Robert Yates Racing
#38 Elliott Sadler-M&M's-Robert Yates Racing
#97 Kurt Busch-Sharpie/Rubbermaid-Rousch Racing
Russell
1968 F250 LWB 300-6
THE 2003 LINEUP
If your good at fabricating I suppose you could put a rack set up on these, but I would suggest finding a donor and just installing a power box/pump.
I think it would be just a bolt on, as long as you found the pump to fit your motor application. The box would just unbolt and put the new on. I would watch the pitman arm though, you may have to change the front linkage to match. I'm not sure, but I would check.
Larry
1967 F100 352/c6
1969 F100 428CJ/4 spd
1959 B model Mack
and a few hot rod FORD cars too
Larry
1967 F100 352/c6
1959 B model Mack
https://www.ford-trucks.com/dcforum/DCForumID73/3322.html
https://www.ford-trucks.com/dcforum/DCForumID73/1760.html
https://www.ford-trucks.com/dcforum/DCForumID73/1519.html
https://www.ford-trucks.com/dcforum/DCForumID73/2296.html
https://www.ford-trucks.com/dcforum/DCForumID73/1639.html
https://www.ford-trucks.com/dcforum/DCForumID73/1613.html
https://www.ford-trucks.com/dcforum/DCForumID73/1338.html
https://www.ford-trucks.com/dcforum/DCForumID73/1231.html
https://www.ford-trucks.com/dcforum/DCForumID73/76.html
https://www.ford-trucks.com/dcforum/DCForumID73/104.html
https://www.ford-trucks.com/dcforum/DCForumID73/509.html
