Brakes,replaced everything,still bad..help!
1978 f150,351M,4X4,SHORTBED,4SPEED. I have replaced everything I can think of,....Master,calipers,pads,wheel cylinders,shoes,hoses front and rear. I have not replaced the porport.valve or the Booster. These two items seem to be working right. Here's the deal..The truck will stop if you push on the pedal hard enough, but it seems to go all the way to the floor. No matter what,I cant get the brakes to even try to lock up. The other dat I was coming home from work and the brakes seemed to quit working. The pedal was very stiff, like I had no vacume to the booster. So, I pulled out the valve to the booster whil the truck was running to check if it was pluged up,seemed OK. I put my finger over the end of the valve to stop the leaking vacume and it kills the motor in 5 or 6 seconds. Is this typical to kill the motor by pluging off the hose to the booster? I have the hose routed to the back of the manifold right under the carb. Do you guys think I need a new MC and booster OR do I need to re- rout the booster hose?
This is usually because the rear drums are not adjusted properly.
Sounds like a bad booster, it does not need to be hissing to be bad.
In my experience, the best thing is to replace the mstr and booster as one unit.
Nitro901
38
09-17-2016 06:53 PM
F-250 WARHORSE
15
08-09-2016 09:51 PM
jtexfisher
08-01-2016 06:51 PM
wilfreeman
20
04-05-2016 10:13 PM
bigreave
11-28-2004 02:23 AM
