third brake light
on
1 Post
It may require one of those common-bulb system logic adapters. You could probably run a wire straight from the brake light switch instead and see if that works... or spend the 5-10 bucks on the logic adapters.
I'm also considering buying / mounting a 3rd brake light for safety and insurance purposes... but I'd like one I can bolt/screw into the top of the liftgate, instead of a stick-on one
