rough start on 98 f150 v6
my 98 f150 starts pretty hard after sitting overnight. It will start fine all day, but after an overnight sit, it needs a good ammount of gas pedal to get going.
It was recently having idle issues while in gear, and stoped. A new airfilter, spark plugs & cleaning the MAF helped bring it up 300 RPM's at idle. It still idles rough at stoplight, but it doesnt feel like its gonna die anymore. I plan on cleaning th IAC this week sometime to see if that helps (per Racer Guys FAQ post).
Any ideas on why such a hard start once, but fine the rest of the day?
RacerGuy always has the good info. He also suggests installing a new IAC instead of cleaning the old one. If your doing the work of taking it off,
just put on a new one, because a cleaned original will often fail again,
and you will have to do the job twice. Be sure to take your negative cable off the battery before doing the work, then let it run 15 minutes when you start it up to reset the battery.
buddss
1997-2006 Expedition & Navigator
28
09-21-2015 08:37 AM
overtimef250
1999 to 2016 Super Duty
13
09-15-2011 01:24 AM
tracyclifton
08-02-2011 10:25 AM
