Auto to Manual Hubs - COMPLETE
#168
https://www.ford-trucks.com/forums/m...all-10802.html
#169
#170
Now I just need some new center caps so they fit flush to the hubs...anyone know what year center caps will fit flush to the MM hubs and look sweet again???
I will purchase a set if anyone has two spares...or can trade mine for them...whatever...am in Wa State...
#171
Get out in the rain / snow / mud?
How about just setting the hubs to LOCK before leaving the driveway, then IF you need 4x4 while out in the foul weather, you just simply shift into it and you do not have to get out. It certainly does not heurt anything to run with them locked. Some people LEAVE them locked all the time, tho I do not recommend it. But, when bad weather sets in, I just lock them, then no getting back out when I need it, and I just wait till I get home again to free them up, if I even do it then.
#172
changing auto hubs to manual.
for some reason I can not get the word message to copy. will some one please email me a copy . thanks kephartron@Hotmail.com
#173
love them
I also used some nice brass plugs (1/4in I think) to seal the back side of the hubs and delete the vacuum input.
#174
Replaced the OE hubs with mile marker's in 2010 on my 00 F350, got our first snow this week and found out the 4wd didn't work, Took the caps off the lockouts and found the fingers that rotate the hub were all broken off on the passenger side. Anyone know if MM has a replacement kit for these fingers. There is a snap ring that holds them in place, you would think there was a replacement kit for this. Thanks in advance.
#175
Manual Hub Engage/Disengage Movement?
Got the Mile Marker Stainless Steel Hubs installed today. These things are stout and they fit very nicely.
Install was extremely easy. A few simple tools and your done. I didn't even have time to finish a beer before they were installed.
Here's the complete write up for anybody that is looking to do them. It's a 1.4 Meg MS Word document.
EDITTED by krewat:
Super Duty Automatic to Manual Hub Conversion.doc
Old link: NOT WORKING: http://webpages.charter.net/rsilvano/Documents/Super%20Duty%20Automatic%20to%20Manual%20Hub%20Con version.doc
EDITTED by krewat:
HOTRODTONY
02-08-2016 05:07 PM
2002, 4x4, auto, automanual, bronco, conversion, duty, f250, ford, hub, hubs, installing, instruction, manual, sd, super, work
