Modular V10 (6.8l)
Fumoto oil plug - with nipple or without?
Old 03-10-2006, 11:06 AM
F150S/C4x496's Avatar
F150S/C4x496
F150S/C4x496 is offline
Guys,
Looks like the "nipple" version might allow for a cleaner changing process. Any downsides to getting one with a nipple? I do go offroad on occasion, but nothing radical.
Thanks
Old 03-10-2006, 04:25 PM
biz4two's Avatar
biz4two
biz4two is offline
No problems IMHO. The nipple allows the use of a down tube...and YES makes the oil change drip free (minus the oil filter of course ).
biz
Old 03-11-2006, 04:05 PM
DJR 17's Avatar
DJR 17
DJR 17 is offline
I have the one with the nipple and have had no issues with it. The only thing I worry about is if it drains all of the oil or not. I haven't tried pulling it off after a drain to see.
Old 03-11-2006, 09:38 PM
Wrenchtraveller's Avatar
Wrenchtraveller
Wrenchtraveller is offline
I have the Fumotos without the nipple and they work fine for me. I have had Fumotos on 5 of my vehicles. They are a great product and I don't want to use a hose so all the nipple is to me is an extra projection I don't want. I still put a little 5/8" screw clamp on the Fumoto as an extra precaution. ( Fumoto recommends this for off road )
As for as how well a Fumoto drains, I have proved this out by doing the following,
I pulled the plug on my engine, let it drain completely. I then installed my Fumoto and closed the valve. I put a jack under the wheel opposite and jacked up the truck a few inches, opened the Fumoto and got a couple extra tablespoons of used oil to drain.
Test result, jacking up a vehicle with a Fumoto drains more oil than an unjacked vehicle with a plug. I love my Fumotos and they make oil changes so quick and easy.
Old 03-12-2006, 09:02 AM
RAH's Avatar
RAH
RAH is offline
I used the Fram easy drain or what ever its called, I have changed the oil once since installing it and i really like it. With hose it stops the oil from shooting half way across the shop when i pulled the plug, and there is no way it will ever leak with the brass cap screwed on it between changes.
Old 03-12-2006, 01:05 PM
captchas's Avatar
captchas
captchas is offline
Guest
with the nipple for me.no problems at all .all it dose for me is allow my draining my used oil into 1 gal milk jugs under the truck then into larger 5 gal cans that i take to the collection center in town.
man go for it don't be scared . wrench turned me on to it and and it's grand. best money spent so far. plus no way to strip the oil pan. one time on thats it.
Old 03-14-2006, 07:44 AM
F150S/C4x496
Guys,
Thanks for the replies. I will be ordering one of the Fumoto drain plugs this week.
