'91 4 cyl. Ranger Towing Capacity
everyone has their own opinion but I know my ranger and it takes skill to tow a lot of weight with these little trucks.
Received 6,693 Likes
on
on
Going even further off topic...
The rearmost leaf spring bracket on my '91 was attached to the frame with rivets. I drilled out the rivets and put on new brackets, flipped upside down. The OEM leaf springs were a bit lopsided and were replaced with Deaver leaf springs. I gained a ton of travel while keeping the vehicle at the same level.
I had an 84Ranger, 2.3 5speed. I was renting a little house and took a lowboy of hay to it to insulate the foundation. I don't know know how much weight was on there....but I do know I nearly lost it because it wasn't loaded evenly, as in too much weight on the front, which took most of the weight off the steer tires. Wheeeeeeeeeeeeeeeeeeeeeeeee
Also hauled a golf cart in it once.
