remove headlights on a 99 Ranger?
I bought some new black headlights that I am trying to install, but cant get the old OEM headlights removed? Ive tried every tool I have, but the pins have these stupid clips over them that I cant get out of the way to unscrew the bolt-ish thing holding it in (I'm a total newbie, can you tell )...
Any help is GREATLY appreciated!
Thanks!
Brandon
Thanks!
Brandon
From the Ford manual
Lamp Assembly — Headlamp
Removal
NOTE: Make sure that the headlamp switch and the ignition switch are in the OFF position.
Pull out the parking lamp assembly.
Remove the screws.
Position the bumper close out panel out of the way and pull out the parking lamp assembly.
Remove the parking lamp assembly.
Disconnect the three connectors.
Remove the two headlamp C-clips.
Compress the headlamp clip and pull out the headlamp assembly.
Disconnect the connector and remove the headlamp assembly.
Installation
To install, reverse the removal procedure.
If necessary, adjust the headlamps. For additional information, refer to Headlamp Adjustment—Photometric Aiming or Headlamp Adjustment—Screen Method Aiming.
Removal
Remove the screws.
Installation
I just used a right angled pick. Put it on one side and pull until it comes us alittle, then switch sides until you get it off. The C-Clips are surprisingly easy once you get them off. Be very careful! My first time I broke 3 of them. They go for $4 a piece at the stealership. I put them back on with a flat blade screwdriver. Push down on both sides until you get it on.
Bikedude987
03-20-2012 09:41 PM
Monana ford Man
01-09-2012 07:33 PM
xc4jokestomper
05-21-2011 09:02 PM
Bad Company
Appearance & Dress-Up
05-09-2010 06:12 PM
