Slow Fuel Gauge on 2005 F250 SD
If you leave the ignition on while refueling, the gauge will come up real slow. This will also happen if you have it in the accessory position (such as listening to the radio with the engine off). The fuel gauge level is averaged to prevent your gauge from jumping up and down when the fuel sloshes around in the tank. If you shut the ignition off while refueling, it should come up right away when you start the truck.
Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Must read if you own a 6.0
https://www.ford-trucks.com/forums/s...d.php?t=325000
See you on the boards.
Enjoy FTE …..
Enjoy FTE …..
Originally Posted by bonehead_98
My truck did the same thing, eventually got to the point where it would take several hours to register correctly. Took it to dealer, they replaced fule level swith in tank. They told me it was a common occurance.
emspjay
29
06-01-2014 12:15 PM
love2truck
09-05-2013 04:19 PM
LFDavidson
04-16-2010 04:02 AM
gl0116
05-08-2005 10:35 PM
