Deck Height
deck height
Mummert mentions problems with a deck height of .03" to .04" with the thicker modern head gasket being to much. When working with a machine shop tell them what you want up front...The block decked. It gets can costly becouse they may want to assemble it to check deck height and then remove everything to deck it.
Tom
Tom
Dan, Tom has given you the straight scoop. Deck height is the height of the deck above the top of the piston (assuming the piston is flat). I believe the dimension you refer to is block height. I have seen it, but can't recall the value or where I saw it.
If you are in a pinch, you can take 1/2 the stroke, the rod C to C length, the piston height, and add some for the deck height, and be fairly close if you don't need an exact figure. By my reckoning, this would put you near 9.7"
Dan, I guess some folks do call the dimension you refer to as deck height, tho I never have, nor am I familiar with it being used that way. No matter, here is a thread where someone asked John Mummert the same question, and Mummert gave the answer.
http://www.y-blocksforever.com/phpbb...3edc9e26ce9f86
Check it out.
Check it out.
Aaron-71
16
05-30-2017 12:30 PM
muscletruck7379
04-02-2006 10:27 AM
74 F100 351m
11-18-2003 09:01 PM
