starter relay
This belongs in another forum, but, what Year, Model, and Engine?
Generally speaking, your relay is suppose to "pass through" the full voltage and amperage of the battery. Disconnect the cable going to the starter, at the relay, and take your measurements on the relay terminal. No more then probably a .1 voltage drop. Reattach the starter cable and then measure at the end of the cable to make sure the cable is good.
