You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I was wondering what is the minimum size for a vapor draw propane tank. I heard you can't use just regular bbq tanks. What about a size like 10" diamatier by 27" tall would that be good enough?
__________________
Craig
99 F350 PowerStroke Dually
86 Buick GN
torque = how hard ya hit the wall. horsepower = how much it hurts when you hit it
Ok, definitly not legal. If you didn't mind the looks, a saddle tank off a pickup or a smaller tank from a car of some kind would do, but I assume it would have to be D.O.T approved for that purpose, otherwise I would even say a forklift tank.
A RV horizontal vapor tank can be frame rail mounted or bed mounted. Horizontal tanks are ASME approved which means they can be permanently mounted. They come in all sizes. A 10 x32 is 7.9 gallons and will fit in between the frame rails of the Ford if you want to mount it underneath. Larger diameters such as a 12 x 32 is about 10 gallons so if you go in the bed, you can use one of these.
You can use vertical style tanks with a vapor draw system. They are DOT approved, which simply means they can be transported full or to be filled. Think of every travel trailer/pop up. They have to be mounted upright and secured so that they can't tip over. Mounting them in a vented toolbox for example works well.
Hope this helps!
__________________
2004 Harley 6.0, Powershot 2000 propane, Diablo Predator, exhaust, etc.
1999 F 250, ATS chip, Powershot 2000 propane, etc.
