534 or 330?
Old 01-29-2006, 07:05 PM
grumpy1's Avatar
grumpy1
grumpy1 is offline
534 or 330?
I have found a 1965 f500 and am considering buying it. The guy that ownes it says it has a 330 in it which was available in 1965. The vin for this truck is f50r673096 and according to my book it says it is a 534. I have done a little research on the 534 and I have found it to be somewhat undesireable. Is there a way to tell the difference between a 330 and a 534? Thanks for your help.
Old 01-30-2006, 01:51 AM
Louisville Joe's Avatar
Louisville Joe
Louisville Joe is offline
I would say it's pretty much certain that truck has a 330 if it's the original engine. The 534 was in the 850 and 900 series trucks.
Old 01-30-2006, 10:06 PM
grumpy1's Avatar
grumpy1
grumpy1 is offline
I think you are probably right. I still can't make since out of the vin saying its a 534. I don't know if the vin is on the door on 65s or not but I was thinking that maybe the door was changed at some point. I would still like to know if there is a way to tell between a 534 and 330 though.
thanks
Old 01-31-2006, 03:27 AM
Louisville Joe
The 330 is a member of the 'FT' family. It's a lot like a 361 or 390 in appearance. The intake manifold goes under the valve covers if you look closely. The Super Duty 534 is a huge engine. Much bigger than any V-8 you would see in a car or pickup truck. Also, I think all the 330's had 2bbl. Holley carburetors. The 534 had a Holley 4bbl..
Old 01-31-2006, 04:04 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
count the valve cover bolts. 5= a FE engine.
tylstruck
51
05-27-2023 04:55 AM
BiGGreen350
Ford Truck Parts for Sale
37
10-27-2014 02:25 PM
BiGGreen350
79
10-25-2014 05:48 PM
kfw21
Large Truck
08-16-2014 10:24 PM
fireman336
12-21-2010 06:55 PM
Quick Reply: 534 or 330?
