Dealership BS'ing me?
OK, I finally got irritated enough to take my 2000 Lariat in to have the strange noise checked out. It only happens when the heat selector is on defrost or floor/defrost. Which pointed me to the compressor bearing. Anyhow, they confirmed the noise was the compresor. However they stated that it was not a repairable part, the entire compressor would have to be replaced ($600). If I'm not mistaken...these can be rebuilt correct? Also, the refrigerant was low, so they topped it off...and BAM...the noise is gone. I'm pretty disgusted at this particular dealer and now vow to never return to them. Thankfully there are 3 other Ford Dealers in our area.
Compressors can be rebuilt but they aren't done on site by any auto repair shop so they are not BS'ing you. Personally, if the compressor is not leaking and it is working, use it until it dies. Mine has made a little noise now for over 30K miles and is still working......
You do not need to have a Ford dealer do the A/C work. Any good shop that deals with A/C can do it and most likely save you a few $$$ to boot. Please note that if you do decide to go with a rebuilt compressor you will need to make sure that it is a quality rebuild and not some cheap, down and dirty job. Use a reputible shop....cheap is not good when it comes to A/C. Aftermarket evaporators and condensors do not last from personal experience so if either of those need to be replaced, use OEM if you want them to last more than 6 months!!!!
