oil pan gasket replacment
i just got done replacing my intake manifold gasket on my 86 f150 351w without breaking off any bolts in the process.i also have an bad oil pan gasket.i read on the forum that you can replace the gasket without jacking up the motor,if so how much clearance would there be if i just dropped the pan to put new gasket in ?could this be done in this manner? thanks
I just changed the oil pan on my 5.0 last month. I'm running the second phase of AutoRX and I think it cleared out a lot of gunk, and I started leaking because of it. Anyway, jacking the engine is quick and easy, and based on the job that I did, mandatory. I have 4X4 and don't know how much different it is than 2WD, but I cannot see a way to change the gasket without jacking. You go from 1" of clearance to 5". 5 inches isn't that much either, but it helps.
Jolly Roger Joe
34
03-06-2017 01:04 AM
oldcoupe42
34
07-07-2010 08:10 PM
t4kne
07-13-2008 08:39 PM
charlesvalentine
1997-2006 Expedition & Navigator
02-09-2002 07:08 AM
