6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
New Twin Turbo Engines On Dealer Lot
Old 11-17-2005, 11:47 AM
mschultz's Avatar
mschultz
mschultz is offline
Stopped by the dealer last night and sitting in the commercial lot, under the tilt hood of a cab-over medium-duty truck was a twin-turbo Powerstroke! My jaw hit the ground! Finally, a way to put an end to the stupid rumors suggesting that the new engine is going to be anything other than International. (Did you ever wonder how so many people actually got to read the actual contract between Ford and International? Who knew so many contract lawyers with idle time and access to corporate records perused over our fair site? And exactly why would Ford seek an inferior engine to replace International?)
The new engine has sequential turbochargers with the outlet from the first turbo feeding directly into the inlet of the second turbo. The second turbocharger was positioned at a right angle to the first turbocharger. The plumbing was not the nightmare I was expecting. The engine looked clean and well-engineered- nothing like the mess of plumbing surrounding the GM-Isuzu.
The catch? It was not until I tilted the cab forward that I noticed this was a V-6! No I am not suggesting that the engine to replace the 6.0 will be a V-6. But it makes sense that International would make use of modular architecture and the environmental technology on the V-6 twin when building the V-8 twin.
I like the fact that the twin set-up is getting run time in a commercial configuration before it hits the consumer market. If the V-6 is any indication, and I think it makes sense to assume that International will make use of the economies of scale here, the new engine looks good. I am excited enough about it to consider holding off a new truck until the new power plant is available. Now if only Ford will resist the temptation to make the new truck look like something Country-style leisure folks use to haul belt-buckles and coolers filled with Zima to the pop music concert, we will be in good shape.
And is there a way we could take some blood from each person who even suggested the new engine would be anything other than International?
-Mike
Old 11-17-2005, 12:01 PM
SpartanDieselTech's Avatar
SpartanDieselTech
SpartanDieselTech is offline
Former Vendor
I found the suggestions remarkable too
The LCF with that exact engine was available as July; We had one on our lot by the beginning of August. I snapped some pictures on my phone but got aggrevated and never posted them...
It is an incredibly clean setup considering there are dual turbos, isn't it?
Old 11-17-2005, 12:30 PM
kw5413's Avatar
kw5413
kw5413 is offline
Yes dual turbos. We have and I am sure we will continue to make the mistake of referring to the sequential turbo strategy as "Twin Turbos" but, as I understand it the primary is smaller than the secondary. The smaller turbo feeds it's big brother. Is this correct Matt?
So, they are not twins.
But, the "Twins" sounds like they are a whole lot more fun the the "Duals"
Don't you think?
Old 11-17-2005, 03:01 PM
BigF350's Avatar
BigF350
BigF350 is offline
That is correct Keith (the smaller turbo feeds the bigger one)
Old 11-18-2005, 06:49 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
I want to see pictures....
Old 11-18-2005, 07:16 AM
kw5413's Avatar
kw5413
kw5413 is offline
You always want to see pictures...
Old 11-18-2005, 12:17 PM
Customz's Avatar
Customz
Customz is offline
and quotations...
Old 11-18-2005, 05:00 PM
uuranium's Avatar
uuranium
uuranium is offline
so are the turbo both being fed by exhaust gas or is it the compressor outlet of the smaller turbo that is feeding the turbine of the larger unit?
Old 11-18-2005, 05:43 PM
Casey's Avatar
Casey
Casey is offline
Exhaust gas feeds both. The second turbo further compresses the air from the first turbo.
Old 11-18-2005, 08:08 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Me to. Now I'm drooling.
Old 11-19-2005, 10:28 PM
duramaximizer's Avatar
duramaximizer
duramaximizer is offline
what was the displacement of the V6?
it should be a 4.8 if it is of the modular design. or close considering the same bore and stroke.
Old 11-19-2005, 10:55 PM
BigF350's Avatar
BigF350
BigF350 is offline
I may just propose a theory.
That if the 6.4l is a 6.0l, just with greater capacity, and that the 4.5l is just a 6.0 with 2 less cylinders?
Old 11-20-2005, 08:25 AM
2003 6.0's Avatar
2003 6.0
2003 6.0 is offline
Pictures Please
Old 11-20-2005, 10:03 AM
Customz's Avatar
Customz
Customz is offline
Test drove a LCF with my dad and uncle yesterday. For a heavy vehicle, it sure does move. The 97 F-450 PSD Flatbad (which the LCF would replace) is still running strong, although the tranny will need a rebuild soon. So my uncle couldn't justify the costs.
Old 11-20-2005, 03:33 PM
NickFordMan's Avatar
NickFordMan
NickFordMan is offline
They move pretty good even with a V6? Man...I can't wait for the V8!!!
Quick Reply: New Twin Turbo Engines On Dealer Lot
