upper A arm question 98 f-150 4x4
can anyone tell me if there is a difference between the right and left A arms on my 98 4x4 i would think there marked for a reason but just wondering because Ive been having loads of trouble with my right front wheel feeling like it has a dead spot when you spin it with the truck on a jack and the left wheel spins smooth without any friction. i have put 3 axle's and 2 wheel bearings in the last 6 months the alignment is good the idler arm is new the lower ball joints are new and the gears were set up by local ford dealership and it has a 6" fabtech susp. lift what puzzels me also is the angle looks to be in a bind on dvr side but pass side looks good and is smooth rolling thanks for your help
