anyone run a mostly stock powerstroke in the 1/4?
Just wondering if its about right or slower than normal?
ran 16.9@83.3 weighs 5800lbs
__________________________________________________
WWW.HOTRODLINCOLN.ORG
"Dog Hair Racing"
2004 GTO ,Almost stock,3790lbs , 1.7 60FT / 12.8@106
1996 F250 Powestroke,3" dp,no cat,5"tip,46637 filter,16.9@83.3
1972 Oldsmobile 442 , under construction
"Dog Hair Racing"
I was just going by what it says in the specs I found online for weight?
1996 Ford F-250
Standard cab
two wheel drive
longbed
specifications ...
Weights:
gross vehicle weight rating 6886lb
curb weight 4443lb
I know my utility box weighs 1300lb (again according to manufacturer)
so 4443+1300 = 5743,,just rounded it to 5800lbs
Am I way off on this?
Ran 17.3@82.1 launching from idle and the other run was powerbraking it to
2000rpm which is as high as I could get it without it breaking tires loose.
Trucks isnt completly stock,
have the 3"dp ,
3.5" from there back,
removed cat
big air filter and the
4k oil temp resistor mod,
Temp mid 50s,
Wind: From WSW at 6 mph
Humidity: 80%
Pressure: 29.95 in.
Dew Point: 54°F
"Dog Hair Racing"
1996 Ford F-250
Standard cab
two wheel drive
longbed
specifications ...
Weights:
curb weight 4443lb
have the 3"dp ,
removed cat
Temp mid 50s,
Humidity: 80%
Pressure: 29.95 in.
Dew Point: 54°F
"Dog Hair Racing"
Originally Posted by cookie88
Ah...in that case I suspect you are probably around 7000 on the scale. Mine is 7820 with just the normal junk in the toolbox....That's a crew cab 4x4.
Guess Ill have to hit the scales at the metal yard now,,you have me curious!
If its 7000lb its a lot more powerful than I thought it was!!
I tried the 10k icp mod but it just fell on its face at 2000rpm though it felt strong as all hell up to that point.
I have noticed since the exhaust and 4kmod the exhaust smokes up black a bit when I get on it.
"Dog Hair Racing"
