Could I have a worse setup for towing?
I've got a 2004 F150 Screw, 5.4, 4x4, 3.55 rear end. Here is the situation:
Here in Mississippi, we don't have much in the way of hills. I pull a 27' Terry travel trailer that has a dry weight of 5900. I had a surprise this past week when we made a roadtrip to the mountains of north Georgia pulling the fully loaded camper. Although I have the 'trailer towing' package, it apparently doesn't consist of more than the wiring harness, transmission cooler and brake controller harness. I now know I made a big mistake in getting a truck with the 3.55 rear end.
I need to do something to increase HP. I'm looking for recommendations that some of you have tried and are happy with (programmers, chips, exhaust, etc). We want to hit the mountains again but this rig really struggled. My budget won't allow for an upgrade to a F250 anytime soon so I'm looking to get the most out of this truck.
Thanks in advance.
Thanks in advance.
Sorry to hear you had trouble. how did your truck struggle? did you have alot of gear search? have you noticed that you have low rpms over say 65 mph? i had lots of gear search and only turned 1800 rpms at 75 mph i got a reflash at the dealer and it made a big difference. if your truck is still under warranty it'll take care of it. here in al. we have some hills not lke the mountains but far from flat and the reflash sure did help. at first i hated my truck and thought i had made the worst descission i've ever made in trading my 97 f150 for my 05 fx4. now i'm glad i did.
3.73's would definately help but it wouldn't be night and day, so don't dwell on that. Some people are afraid to let the engine speed run up - but that's why they have an OD cancel button, use it!
There's no shame in slowing down a bit for a hill, you won't get there much faster trying to stay at 70 mph going up the hills but you'll burn alot more fuel trying to do that.
Thanks
Thanks for the replies thus far. There wasn't a lot of searching for shift points going up hills. I drove between 60-65 mph on the interstates (I-20 from MS, I-75 north of Atlanta). Hitting some of the mountains (up around Blue Ridge, GA), I was lucky to hold at 50mph on an uphill grade (65 mph speed limit)
Has anyone installed a tuner and actually towed after doing so?
I have an Xcal2 tuner on my truck and it does make a difference towing, not night and day either but an improvement. The best thing it does for towing IMHO is alter the trannies shifting. I have the 3.73 gears in mine and wish I could have gone to at least 4.10's. If you're going to be doing a lot of towing in those conditions I would go to 4.10 gears, and hopefully you also have trailer brakes?
Change the front?
Originally Posted by ford390gashog
if you have to change to a 3.73 gear than you must also do the front diff the same way. i think the above posters are missing that point.
Thanks.
you are looking at 1200.00 a diff. so at least 2400.00
Tuner
Originally Posted by wheelerfreak
So the Xcal2 I bought is listed at $400 (but was bought for less....
Thanks for the input.
