1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 f250 rough idle, rough shifting
Old 11-16-2005, 08:33 AM
chas111's Avatar
chas111
chas111 is offline
I have a 2000 F250, SuperCab, 5.4 triton, 100,000 miles. It's been a great truck - got it at 63,000 miles. Once engine warms up, it has rough idle, and shift rough. I can give it gas to RPMs up and it smooths out some but is low on power. If this was my 76 F150, I would guess the vacuum hose off the intake manifold to the transmission came loose. Any ideas?
Old 11-16-2005, 08:36 AM
FortyFords's Avatar
FortyFords
FortyFords is offline
Ever change the plugs? or boots How about Cop's (coil on plug)
Clean the IAC
Clean the maf
Change the fuel filter
Chk the fuel pressure at Idle and part throttle
Just few things to keep you busy
Ever have any chk engine lights?
Rich
Old 11-16-2005, 10:18 AM
chas111's Avatar
chas111
chas111 is offline
Had the plugs changed out 3 months ago.
No check engine lights at all.
Thanks for the tips. Will check tonight.
Old 11-16-2005, 11:03 AM
FortyFords's Avatar
FortyFords
Iac and maf would be first then.
Just got your msg
There is a picture in this forum.
Go to the top of the forum ,you will see a Sticky about FAQ's for superduty's
click on the Truck to get in, then engine+transmission in there you will find a picture.
Rich
Old 11-17-2005, 07:31 PM
captgarysr1's Avatar
captgarysr1
captgarysr1 is offline
captgarysr1
have 5.4 with same problem...... had problem...... vacume hose on back of intake manifold gets heated up against firewall and gets hole in it check this first may save you alot of looking.
Old 11-26-2005, 04:58 PM
chas111's Avatar
chas111
chas111 is offline
I found the problem!! Took it to AutoZone from suggestions in the forum from other users that have had engine issues. Even though the check engine light was not on, I had the young man at AutoZone hook up his code scanner. It immediately showed misfire on Cylinder 1 & 2. Went home and took the coil pack and boots off...significant moisture came out of the boot. I cleaned the spring connector with electric contact cleaner, sanded the contact ends, and added a dab of di-electric grease. Runs like a top!
We had a significant temperature inversion from cold to very warm and humid with hard driving rains. My guess is that the Cylinder 1 & 2 suffered a little sweating during the process, thus the moisture being trapped.
Old 02-13-2016, 03:57 AM
sorch2008's Avatar
sorch2008
sorch2008 is offline
Have an 08 with the same symptoms. I hope thats my prob too. Much appreciated with the info.
Cyka
07-28-2017 08:27 PM
Chuckwagon101
07-22-2017 07:57 PM
67 FE Fan
03-27-2017 06:58 PM
flounder19
06-05-2016 06:09 PM
TxFord1969
03-26-2016 09:24 AM
Quick Reply: 2000 f250 rough idle, rough shifting
