Brake Light
Old 11-15-2005, 03:26 PM
Chewy31's Avatar
Chewy31
Chewy31 is offline
Brake Light
I took the initiative to replace my brake pads all around my truck. The pads came off and were replaced easily.
Problem - the brake light is now on?
Suggestions?
Old 11-15-2005, 06:01 PM
cleevesj's Avatar
cleevesj
cleevesj is offline
Is it the brake light or ABS light? If it is the brake light, the switch probably just got out of adjustment. You can readjust it very easily. It is attached the the brake pedal. If it is your ABS light, It would probably be the sensors not reading correctly at eh disks. Did you replace the disks when you changed the pads?
Old 11-16-2005, 08:10 AM
Chewy31's Avatar
Chewy31
Chewy31 is offline
brake light
I just did the pads. I was away on a hunting trip and the brakes began to squeal. I picked up pads - but not rotors - they apppeared to be just fine.
The brake light - red light - is on now. The light began to flicker some days ago and now its just on when the truck is on.
Old 11-16-2005, 09:25 AM
lancekilgore's Avatar
lancekilgore
lancekilgore is offline
Do as cleevesj says and adj the brake switch, or it could be going bad. If the adjustment is good then check gor bad wires.
