New to me truck with 4x4 problem
It got a 97 4x4 with a 4.6 for a very good price. All power, automatic, 110,000 miles, and true duals. Sounds mean. I checked for cracked doors and leaky windshield and there are no signs, but may have leaked in the past and been fixed, also no signs of engine oil leaks in the common spots. I'm not sure if there is a problem with the power options not working all the time cause i just got the truck last night. The only problem I'm sure of is the 4x4. It is stuck in 4-hi. It has the dash button system no floor shifter. Doesn't matter what it is put in stays in 4-hi. After serching the posts I'm coming to the conclusion that it is either the GEM or the motor on the trans case. Which should I check and how do I check. Or is it probably somthing totaly different. I'm used to the pre 97 trucks and this new one is totally differant so I'm kinda lost. Any and al help is appreciated. Thanks
