WVO sources
Old 10-06-2005, 09:46 PM
onioncasserole's Avatar
onioncasserole
onioncasserole is offline
WVO sources
What are the best sources to attain higher grade WVO? From what I understand the fast food joints have some of the worst grade WVO to convert into biodiesel.
Old 10-08-2005, 11:22 AM
cookie88's Avatar
cookie88
cookie88 is offline
How is VO graded? Who uses VO in bulk besides resturants?
Old 10-08-2005, 09:27 PM
onioncasserole
There is no grade scale that I know of for VO or WVO except the possible uses. Fast food restaurants use a certain type of VO which characteristics change when they use it for their specific cooking style. From what I understand these characteristics are less ideal for converting into biodiesel b/c of higher water and waste content. I E More labor to convert it. I'm thinking Chinese/BBQ/seafood restaurants MIGHT be a better WVO to convert. That's only a guess. What do you think?
Old 10-29-2005, 08:31 PM
joeblow69's Avatar
joeblow69
joeblow69 is offline
Chip places use it. Like lays potato chips. But they use 1000's of gallons. The best places to get WVO are small mom and pop places especially Asian places. They tend to use the oil lightly, often change weekly, and are happy to give it to you.
The most common oil I get is Soybean oil.
Joeblow69
Two tank WVO system.
Hotstk, Vormax, A1000, and Vegtherm
Old 10-30-2005, 06:56 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Talking
I don't care where it comes from! I am hauling from 38 resturant's in 2 states. Some is better than others, alot depends on how often they change it. I do isolate NEW oils to check for excess water. If the new oil does'nt contain to much excess water then it goes into the bulk tank to be processed. If i find excess water in oil from a new resturant I have a little talk with the owner's and convince them NOT to use water to clean there grill's. Most of the water contamination comes from using water to clean the hot grill's. FABMANDELUX.
Old 10-30-2005, 09:07 PM
Ed Willmott's Avatar
Ed Willmott
Ed Willmott is offline
Wow Fabman that is a lot of WVO!!
How much BD and glycerin do you end up with, say from a batch that starts out as 50gal. WVO?
What are you doing the glycerin?
Old 10-30-2005, 10:06 PM
fabmandelux
Talking
About 400gal/wk!! I just got word friday that my deal with one of the french-fry plants here [ we have 7! ] Can you say mcdonald's? accepted my offer, and I will be hauling 500 gal/wk from them. Only 6 more plants to go!!
50 gal wvo + 10 gal methanol + 4 lbs lye = 50 gal biodiesel, 10 gal glycerol.
Glycerin now being used for heating new 300 gal process tank. Just found a .5 ton/hr pellet-mill for under $1500. Thinking REAL hard about buying it and pelletizing straw/glycerin for pellet stoves! FABMANDELUX.
Old 11-02-2005, 04:38 PM
kennedyford's Avatar
kennedyford
kennedyford is offline
Fab I need your expertise now. Can you send me pics of your methanol recovery? Also a pic of your chunks vs juice seperator? I got my little setup but I need your advise again. And how do you mix your lye and methanol? Mine seemed to take too long to dissolve. Email please.
Old 11-02-2005, 07:57 PM
fabmandelux
I will post pictures of my Methanol Still as soon as my new camera arrives. My "heater-cleaner" pictures ARE posted in my gallery. If you go to my gallery you will see an inclined trough which is where the particles are seperated from the oil. I will post pictures of my Methaoxide mixer also. It takes approx 30 min to mix the lye and methanol. I have a thermometer installed in the tank, when you mix lye and methanol it is an EXOTHERMIC reaction [ it creates it's own heat ], so I watch for the temp to rise to about 120 deg F, When the temp falls to about room temp it's ready to use! My camera SHOULD be here the first of the week, and I will post new pictures then. FABMANDELUX.
Old 11-02-2005, 09:45 PM
kennedyford
I travel to Oregon and Washington quite a bit. Would it be possible to see it in action later this month or December?
Old 11-03-2005, 08:33 AM
fabmandelux
Talking
Yes, you are welcome to visit, but please hold off till mid december. I have 2 speaches to deliver to our county gov this month [we are trying to put together a biodiesel farm co-op ] and I'm streached mighty thin right now! I also bought 2 bankrupt busnesses that need to be restarted this month. Along with building our new processer I have a real full plate right now. FABMANDELUX.
Old 11-03-2005, 08:51 AM
kennedyford
I will let you know way in advance if im gonna make it that way. Im gonna have some sort of trailer behind me either a fema trailer or fema equipment or dealer travel trailer. So i will have to park it or make arragements in advance anyway. Thanks
zhilton
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-30-2009 07:32 PM
tjbeggs
06-27-2008 03:00 PM
luvemhot
13
06-03-2008 10:59 PM
Orpackrat
10-14-2006 12:03 AM
Quick Reply: WVO sources
