before i go and get some ball joints.....
on
1 Post
I have noticed a tire wear patten that is on the inside of the front tires. i also had removed the swaybar so i can replace my bushings. however i still have a clunk from the floor board. do y9ou guys think its the ball joints? How do you tell if the ball joints are bad?
Possibly, but if the ball joints move with just hand pressure they are completely shot.
You can jack it up and pry up on the tire with a seat rod to see if there is any play in the ball joints. The tie rod ends, if bad, will have some play in them just pushing the tires left to right by hand. Some folks try to compress the rod ends with a large pair of channel-locks looking for play...never tried that one myself.
on
1 Post
well belive it or not i called the dealer down at the coast that did the alignment. and i told them of the tires wearing out pretty bad etc etc. they are going to send a refund check for the alignment! i cant belive ford is going to do that!
some past history on the truck
6 inch superlift suspension kit
35 x12.50 bfg's
this was the running gear that was on the truck but i had to get rid of it. the truck was useless. it had a hard time pulling trailers and the goosenck i couldnt even pull. not to mention not a shop in town could align it nor balance the big tires right.
35 x12.50 bfg's
