And yet another update
I know I haven't shown many updates lately so here you go,
Here is the carbon fiber dash inlay with all autometer guages
https://www.ford-trucks.com/user_gal...=91909&width=0
Another view
https://www.ford-trucks.com/user_gal...=91912&width=0
My razoo home made & polished steering column
https://www.ford-trucks.com/user_gal...=91911&width=0
The shifter cover / switch panel, note the red button is one of the two master kill switches, hit this button and it kills all power to the truck along with the engine, also not the GF diligantly working on the border for the carpet in the back ground,
https://www.ford-trucks.com/user_gal...=91910&width=0
The roll pan , a pair of L.E.D tail lights will mounted behind the slotted openings,
https://www.ford-trucks.com/user_gal...=91913&width=0
This just shows the fuel pump, & battery mounting,
https://www.ford-trucks.com/user_gal...=91914&width=0
Coolant tube & fan relay,
https://www.ford-trucks.com/user_gal...=91915&width=0
Brake line routing, both coolant tubes can also be seen in this pic
https://www.ford-trucks.com/user_gal...=91916&width=0
Master cylinder & proportioning valve,
https://www.ford-trucks.com/user_gal...=91917&width=0
And here is how the truck sits with the bed on it,(edit) forgot the pic,
Here you go
https://www.ford-trucks.com/user_gal...=91918&width=0
enjoy the pics,
as usual all coments and criticism is welcome,
Another view
Here you go
enjoy the pics,
Thanks for the kind words, The engine details are still being decided, I know it will be over 500 ci aluminum heads (one of the A-style) eliminator premier block (after market 460 block) single carb , no blower or nitrous, and the goal is a thousand ponys, the check is on its way (nothing like spending out of the retirement for the sake of plying in the mud) I just need to get this thing sold ( ebay item #4581768934 ) that should help things along aswell,
