no nothing is clogged i dont know because i tried 3 different pcv valves and dont know which one to use because it runs differently with all of them, even though they are all the same ones. I am starting to get irritated with this.
yes if you remove it it can be cleaned, if it fixes the problem, then guarrented it will have to be replaced, most of the time the cleaning is only a temp fix.
