What's wrong with my steering?
Hello,
Here it goes... I installed a 6" skyjacker lift with brackets on the front and coils (2WD) Stabilizer and pitman arm (1 year and a half ago) .
Ever since I lifted the truck, when I make a close turn (U Turn for example)
1st: the steering doesn't return to a straight position (I have to quickly return the steering wheel myself every time I turn too much, of course this way too dangerous) It's like if it would be getting locked or stuck for some reason
2nd: the tires screech when I turn too much and are wearing on the outside because of this.
I also recently replaced all the steering components (a set of camber caster bushings able to correct a 1 degree problem it had, drag links, etc).
I corrected the problem with a set of new polyurethane bushings for the front end (radius and pivot arms), When I installed these polyurethane bushings (3 months ago) the turning problem dissapeared along with the tire wearing issue.
The frame cracked recently where the suspenssion brackets are bolted and welded.
Now it is re-inforced and very well welded but the problem came back as soon as I repaired the cracks even after alignment.
Any ideas???
thanks so much for your time.
Any ideas???
Add in the frame cracks, I think something is so "off" things are getting worn out too quickly. I'd seriously go through the front suspension, to make sure it's on 100% correct, nothing is bent or damaged, then have it aligned by a non-sears, non-autozone shop. Lifted trucks require a little more effort in setting the alignment correctly, because as you lift the truck the factory values are off a "hair", and a lot of shops don't understand this. Especially with the return-to-zero... and the reason is because the wider the tire, the less effective toe-out for return-to-zero is, and also because the higher up you are, the more sensitive your truck is to toe-out settings, so often it's minimized, which aggrevates the problem.
Something is seriously wrong there...
You may not like this.. but it sounds to me something is bent, and the alignment shop tried to 'align the bend' out which rarely, if ever, works.
