289 hipo?
on
Do they have screw-in rocker studs? Of course, somebody could have added screw-in studs later.
The clincher for identifying Hi-Po heads is the valve spring pockets. They are cast into the head, and serve to eliminate valve spring "walk". Here's a pic of Hi-Po heads:
http://mustangandfords.com/techartic...mage_large.jpg
I'm not too sure about that casting number. The 289 Hi-Po was built from '63 to '67, and that's a 1968 casting number...when the 302 was introduced. But I have seen overlap on casting numbers before, so that's not set in stone.
