Run slow at startup
Run slow at startup
I have a 1996 F-350 with a powerstroke diesel 7.3 . When I first start it up it has very little power. You can put it on the floor and it acts like it has no power. But once it warms up it will take off good and have good power. I was just wondering if this normal for a powerstroke?
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Enjoy FTE....and
That sounds like the exhaust backpressure system operating normally, however, for it to be normal certain conditions have to be met. The ambient air temp must be below 45 degrees F, and the engine oil temp must be below 167 deg F. If the backpressure valve is operating outside of those conditions there is a malfunction in the system.
