Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-30-2005, 09:02 PM
51frrdtrk 51frrdtrk is offline
Garage is empty, add now
51frrdtrk is starting off with a positive reputation.
"HELP" No oil pressure
Recently converted my 51 to 12 volt. Installed new gages with new sending units. I now show low or no oil pressure. With the old gages the oil pressure was low (10lbs.). I removed the oil line going to the filter and screwed in a different gage with the same results.
The engine does not knock or rattle.
I removed the oil pan (pan was very clean) and installed a new oil pump with the same results (10psi or less).
Removed drain plug and checked on oil pickup clearance. Pickup is about 1 inch from bottom of oil pan.
Anyone have any suggestions.
__________________
CRASH
  #2 (permalink)
Old 08-31-2005, 08:47 PM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
What weight oil are you using, look at the site below it has some real good troubleshooting tips for Flatheads
http://www.btc-bci.com/~billben/flathead.htm
  #3 (permalink)
Old 09-01-2005, 08:24 PM
Have tried different types of oil. 10w30 and straight 20w and 30w. Still no pressure.
I checked the web site you mentioned and will force oil down the oil sending line into the pump, then try it again.
__________________
CRASH
  #4 (permalink)
Old 09-02-2005, 07:57 PM
Guess what, I have got oil pressure...
Forced oil into the line going from the block to the oil pressure sender and filter. Hooked line to guage and low and behold 50 lbs of pressure. Removed mechanical guage and hooked line into sending unit and filter and it shows 40 psi..
Thanks for the web site info '51 ford fan'.
__________________
CRASH
  #5 (permalink)
Old 09-03-2005, 12:23 PM
51ford fan's Avatar
Your welcome, glad I was able to be of help.
  #6 (permalink)
Old 09-03-2005, 07:09 PM
Now i have an extra oil pump if anyone is looking for one. It still floors me when i think that forcing oil the wrong way took care of the problem. I evan took the line off from the guage and ran the engine with the oil running into a cup. You would think that that alone would let get the oil flowing.
Once again thanks for the hand "51 ford fan".
__________________
CRASH
Tags
flat, flathead, ford, head, loses, low, oil, pressure, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
