Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 08-29-2005, 10:29 PM
steinjr steinjr is offline
Garage is empty, add now
steinjr is starting off with a positive reputation.
Newbie "Power" Question - 2002 HD F150
I just picked up a 2002 HD F150 w/ Supercharger. It has 60k miles... The truck seems to have a very quick engine response when it is moving, but from a dead stop it won't spin the tires when I floor it. Is this normal? It does take off quickly... Is there some sort of anti-slip rear end or do I have a problem? My older F150 with a 4.6 spun the tires accidentally all the time...
  #2 (permalink)
Old 08-30-2005, 06:30 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #3 (permalink)
Old 08-30-2005, 10:29 AM
haystacker haystacker is offline
haystacker is starting off with a positive reputation.
I have a 2002 H. D. with the 03 lighting upper pully, S.S. full lengh headers, preadetor chip. It also does not spin the rear tires from a stop. These trucks have limited slip Diff.
  #4 (permalink)
Old 08-30-2005, 05:45 PM
stevef100s stevef100s is offline
stevef100s is new and has a neutral reputation at this point.
Must be the wheel base and extra weight. I've had a 99 Lightning, and now a 03. Both SMOKE the tires from a dead stop.
  #5 (permalink)
Old 09-01-2005, 07:14 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Depends,
I found the lightning to be easily able to melt the tires...
I've never driven a HD, but with sticky rubber, a tight limited slip rear end, and good pavement, I could see it not spinning off the line. If you stabbed the throttle vs smoothly going to WOT, you'd have more of a chance.
The lightning's auto tranny is setup a little stiffer, so more abrupt power is sent to the rear wheels. The HD is a little smoother, so that power transfer is going to be softer/smoother, making it "difficult" to spin the rear tires.
__________________
Justin
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
