tapping
tapping
got a question for you fellas, my 02 f150 with the 5.4l has a bit of clatter. Not so much you here it with the hood up, but idling say against near a wall I can hear some tapping underneath. Now I know its not piston slap cause the tapping doesnt go away after warm-up, not very loud either but your ears get trained to every little sound your truck makes. The noise has been there for quite some time now and it hasnt become any louder but it makes me think either sticky or worn lifters or maybe worn cam lobes but I'm not sure. The truck runs like a champ with no engine problems accept the noise. This normal or shoud I be concerned?
Originally Posted by Octane
I thought the 5.4L didnt have lifters?
Octane
Octane
The sound is more like a single tick, like you can hear the cam lobe hit the roller finger as you said. Its more pronounced when your beside the truck on the lower half of the engine, but in front of the truck nothing. Ive had advise from the service dept. at ford and my exhaust guy and both said its a normal occurance in these 5.4's but I want a second opinion, anybody else with the same thing?
Ford calls them tappets- aka lifters- just put a set in a 04 Mach 1( for a ticking noise, Ford hotline wanted to do this before eng. replacement)- 16 in each head on that one!!! Also stick with the weight oil on you engine lable or on top of oil cap, esp when weather turns cold. Mod engines run MUCH tighter bearing clearances than push rod engines!!!!
I-m tech, is there a TSB or bulletin out on this? The repair is a new head right?Are you doing customer pay or are they warranty repairs? I only ask because we haven't seen any in for guide noise , just oil leaks at rear of right head. Used to see alot of 351cs and ms and 400s for guide noise in the 70s and early 80s though!!!
timbersteel
20
07-18-2012 02:09 PM
Contingen-Sea
09-06-2011 02:24 PM
Vijay
General Automotive Discussion
06-17-2010 02:49 PM
