Fog lights with high beams
Originally Posted by Eric Landstrom
What needs to be jumped on the light switch to enable the fog lights to remain on with the high beams?
If you've got a photo, that'd be cool as well.
BTW: I've done a search and could not locate a how-to.
Thanks.
I did the mod on my '05 and my neighbor took an interest in what I was doing so we figured out how to mod his 2001 F-150. Now we both have better Bambi vision.
i use relays to provide full power to fog lights when key is on, and also to turn them off when turn signal is on(55 watt turn signals), also have driving lights that come on with high beams. high beams and drivers also come on with a long enough signal from horns(electric and air). don't forget diode so horn is quiet when lights come on.
I had a ford ranger Edge 2001 and did the same mod but didn't have to run a ground wire, simply bent the pin back and plugged it in and there ya had it...both brights and driving lights at the same time. Of course the Ranger had it made cause you could run the driving lights without the lights being on. Maybe that was the diff??? Anyone try it without a ground??
Allen
Allen
People asked so here is a link to a how-to on moding your fog lights on your 2004-2006 F-150
