Directional Relay buzzzzzzzz
First thank-you in advance for your advice<O
I have an 03 F-350SD with the 7.3 4X4 Auto trans<O</O
The Directional Relay (flasher) ford part #F65B-13350-AA constantly buzzes I
replaced the relay and it still buzzes. The buzzing will stop if you apply the brakes
turn signal or emergency flashers. The bulbs are all good and all work. I took the brake light switch apart the contacts all look good, no burning on the contacts.
Any suggestions.
Any suggestions.
I think I figured it out I beleave it is the combo switch I pulled it out and played around with it whil still connected to the wireing harness I can get it to stop buzzing for a short period of time but it will return if i wiggle the switch or tap on it so it looks like the switch is the problem.
websurfer
1997-2006 Expedition & Navigator
19
02-21-2024 06:19 PM
FuzzFace2
1098
11-05-2022 11:07 PM
Cdn4X4
10-04-2016 12:48 PM
